CO2 production from boiler combustion gases
I work for an Ammonia & Urea producing plant.
We are interested to increase our actual capacity of the urea plant. We have an excess of NH3 but need an extra amount of CO2 (in the order of 22 Ton/hr maximum)
We are thinking to install a boiler (Natural gas fired to get CO2 from combustion gases.
The natural gas may contain H2S: 0,5 - 2 ppm & HRS: 0.5 - 2 ppm. Average CO2 content 0.7 Mol % v/v
I will very much appreciate if someone can tell me which are the the most important technologies that can design this type of system and how to contact them.
Also any other configuration to obtain CO2 will be considered.
RE: CO2 production from boiler combustion gases
In case you get any reply from any technology suppliers do keep me posted.
CH4 + 2H2O --> CO2 + H2; by fermentation of a sugar to ethyl alcohol + CO2, as in C6H12O6 --> 2 C2H5OH + 2CO2; by thermal decomposition of carbonates (lime-kilns) CaCO3 --> CaO + CO2; from natural CO2 gas wells; int the production of sodium phosphate: 3Na2CO3 + 2 H3PO4 -->2 Na3PO4 + 3 H2O + 3CO2.
CO2 is generally purified by efficient absorption in alkali (carbonate and ethanolamine) solutions (not in water!). There are plenty of processes for that purpose.
I hope the above short list of processes may be of help.
Normally the ammonia urea complexes are stoichiometrically balanced. Either there has been a change in plans for the extra ammonia or your feed composition to the reformer has changed.
