Synchronous Reactance for Induction Motors?
Is the synchronous reactance a parameter for asynchronous induction motors or does it only apply to synchronous machines? If so, how does one calculate it from typical equivalent circuit info?
Also, how does one determine the transient time constant on an induction motor in the event of a fault?
Is my assumption that this parameter is the time it takes for the initial subtransient fault current to reduce to the transient fault current correct?
RE: Synchronous Reactance for Induction Motors?
