Drawing views on layers?
Is it possible to create a drawing view on a layer that I can hide or show to reflect different configurations of similar parts for manufacturing?
I am generating multi-sheet drawings for manufacturing and would like to be able to easily use 1 .slddrw file. As long as the only changes are the part number, description, material, etc... there are no problems in simply changing configurations and updating the drawing. When a part has a geometry change the dimensions are not able to update. I now have to delete the dimension(s) and replace them.
I would like to find a way to create drawing views of my "base" part on a layer, then copy the drawing view(s) to another layer. I would then change configurations and replace dimensions as necessary. I would then turn layers on or off to see the desired drawing in a single file.
RE: Drawing views on layers?
BBJT CSWP
