welding in carbon steel with low alloy steel filler
is production welding in carbon steel material with low alloy steel filler or vice- versa allowed as per ASME code..?
RE: welding in carbon steel with low alloy steel filler
Can you please share the details of your qualified welding procedure which you need to use? This way, I may help you with the approval ranges.
