How to update an Overflow Tabular note ?
Hello
I have created a tabular note 800mm high.
As it is too high to enter in may sheet, I have overflowed it by defining the maximum height 500mm.
I've got now a first half table 500mm high and a second half table 300mm high.
Problem : when I modify a cell of the second half table, the update doesn't work.
Do you know why ?
For information :
- if I modify a cell of the first half table , the update is correct
- if I define the maximum height to 2000mm and then come back to 500mm , update is correct. But not very interesting process...
RE: How to update an Overflow Tabular note ?
Try this post : http://eng-tips.com/viewthread.cfm?qid=349909
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Interesting. I have just created a table and edit this table with spreadsheet. Then, I have changed in spreadsheet the value for the cell in second table and it worked. The cell was updated.
What kind of modification are you doing? Just a change of the cell value or something else?
Did you try to update with Tools/Update options?
I have done my test on Nx7.5.5.4.
Hello SvenBom !
I still have the problem...but I'm going on vaccations.
So let's see on September.
Thanks for your support !
Best regards.
