active coils in compression spring?
how to measure number of active coils in compression spring? will someone explain
RE: active coils in compression spring?
http://i.ebayimg.com/t/MOPED-SHOCKS-11-Motomarini-...
the lower 5 or 6 coils on these springs on these moped rear shocks are already touching each other, so can't join in any reindeer games. They are not active. The other 6 or 7 coils are active. The upper most coil is pretty much not active, and much of it is ground off to create a flat surface too.
The coil spacing on these springs varies considerably. As load is applied the closely spaced ones would touch and becom inactive.
http://i.ebayimg.com/t/TRIAL-MONTESA-COTA-348-SHOC...
