How vulnerable is CMU to water damage or breakdown?
I'm working on a project where we are replacing a pumping system. The walls of the room are made of painted concrete masonry unit. The paint has not protected well against water, however, and water leaks through to the other side of the wall. It has been like this for years.
Luckily my organization now has money to fix things. Should we completely replace the wall? Will CMU degrade from moisture?
We are wondering if just repainting/resealing it would be sufficient. All it supports is the ceiling above it.
RE: How vulnerable is CMU to water damage or breakdown?
