Test Requirements for small 16 gallon tank
Hi All,
We need to make a small 16 gallon tank to act as a intermediate tank between day tank and filling machine.
The tank needs to be designed for 14.5 psi internal pressure and full vacuum.
MOC is AL6XN and tank will be designed as per ASME code but it will not be stamped.
I want to know for this tank what tests are required. Do we need to have radiography and ultrasound test. Or dye penetrant test and hydro test will be sufficient as per code.
Let me know if any other information is needed.
RE: Test Requirements for small 16 gallon tank
