Views created using formulas.
I am trying to make a genaric template that would save me a lot of time in the long run. I have an idea of what I want to do, I just have no idea if it is possible.
I have a drawing that shows an assembly that can be installed in two differnet configurations. Its mounting bracket can swing around depending on what is available to bolt to.
Depending on the configuration the various views need to represent that.
What I would like to do is have a formula in the tree that has multiple values and depending on the value views on the sheet would change.
I see it similar to an IF THEN Statement in excel.
Example:
IF(or(parameter="config1",show="view 1"),(parameter=config2",show="view 2"))
Is there anything I can do in Catia V5 that would result in something like this?
