Bar supports for galvanized metal deck / composite slab
Should Class 1 or 2 bar supports be used for galvanized metal deck / composite slabs? Class 3 bars seem inappropriate since the idea is to protect the steel. Also, if the deck is vented, the bottom surface is more exposed. From a cost standpoint, it seems like plastic chairs would be the cheapest option anyway.
RE: Bar supports for galvanized metal deck / composite slab
