Chemical compatibility of hydrocloride acid
Understand ss316 or any metals is not suitable to handle acid,
Please advise any suitable pump materials that could resist this hydrochloride acid
Other chemical would be sulfuric acid
RE: Chemical compatibility of hydrocloride acid
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
The concentration, temperature, impurities, and mechanical stresses must all be taken into account.
Design for acid service is not for amateurs.
Plymouth Tube
Endstainless:
Impurities,mechanical stress, temp, concentration does it directly proportional to corrosiveness of the casing material ?
Concentrated HCl acid at 80 C is best handled in Teflon-lined equipment. If you must use metals, your choices are Hastelloy B, zirconium or tantalum. Both HB and zirc are only resistant if there are no oxidizing ions like Fe+3 present. There are no other choices I'm aware of.
Be aware also that the velocities in pumps are high, so erosion-corrosion can be an issue. You're far safer with the lined construction.
