Error: Modeler error: curve crosses edge
I have a drawing which always needs the section lines adjusted before it can be updated. The error message is "Error: Modeler error: curve crosses edge". What exactly can I do to fix this issue? Is it in the assembly model or the drawing?
NX 6.0.5.3 in Windows 7
Mechanical designer
RE: Error: Modeler error: curve crosses edge
I would take this up with GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
But I do need to warn you that since you running software that is no longer officially supported, you really should upgrade to the lastest version of NX and if the issue it still there THEN contact GTAC since they can't always help when you're that far out-of-date (since NX 6.0, there have been four, soon to be five, releases of NX).
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
