How to realize this Face Blend
Thanks in advance who can help me to realize a blend like the unattached Face Blend (4)
Didier Psaltopoulos
http://www.psi-cad.com
RE: How to realize this Face Blend
See the attached model. This is the only approach that I could get to work. It should be OK since it's still using the original 'body' as the source for the faces of the 'Thicken' feature.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John
You are the best. Its a long time that I had not thought to place a blend on the opposite side
Didier Psaltopoulos
Hi SvenBom
Your surfacing technique is also a good solution
Didier Psaltopoulos
