Inability to set SECTION=ELBOW for elbow elements in Abaqus/ CAE 6.11-3
I would like to model a simple pipe structure with any of the elbow elements available in Abaqus, for instance the beam element ELBOW31. In the Mesh module I successfully assign ELBOW31 as Element Type but it is also needed to assign an elbow section in the Property module. The problem is that when I create a Beam section in the list with the profiles I do not see "Elbow". In the Abaqus manual for Beam Section it says "Set SECTION=ELBOW for elbow elements, which are available only in Abaqus/Standard." (http://abaqus.ethz.ch:2080/v6.11/books/key/default...). In my version Abaqus/ CAE 6.11-3, Abaqus/Standard in the product employed in the simulation process so I don't understand why I can't see Elbow as an available cross section profile for beam elements?
Can you give me a clue how could I employ elbow elements in my analysis?
Thank you for the help in advance!
Yordan Venev
Yordan Venev
RE: Inability to set SECTION=ELBOW for elbow elements in Abaqus/ CAE 6.11-3
I got to know the solution for the problem I had.
An Elbow section cannot be specified in /CAE. That’s why do so: specify the beam as a pipe-section in /CAE. Then you have to write out the inp-file from /CAE using:
Job -> Write input
Then you get a inp-file that you can edit like:
** Two, or more, asterix give a comment line.
***Beam Section, elset=_PickedSet2, material=steel, temperature=GRADIENTS, section=PIPE
*Beam Section, elset=_PickedSet2, material=steel, temperature=GRADIENTS, section=elbow
Data line 1
Data line 2
Where according to the Abaqus 6.11 keyword manual *Beam section:
Data lines for ELBOW sections:
First line:
1. Outside radius of the pipe, r.
2. Pipe wall thickness, t.
3. Elbow torus radius, R, measured to the pipe axis. For a straight pipe, set .
This value is not written for the Pipe-section so it have to be added.
Second line:
Enter the coordinates of the point of intersection of the tangents to the straight pipe segments
adjoining the elbow, or, if this section is associated with straight pipes, the coordinates of a
point off the pipe axis. The second cross-sectional axis will lie in the plane thus defined, with
its positive direction pointing toward this off-axis point.
1. First coordinate of the point.
2. Second coordinate of the point.
3. Third coordinate of the point.
( Also use:
*Preprint, echo=NO, model=YES, history=YES, contact=NO
So that you can look in the dat-file that all detailed input that is written there is what you specified. )
After you have made these change save the inp-file under a new name and then run Abaqus using:
abaqus job=new_name
or:
abq6113 job=new_name
Best regards,
Yordan Venev
