Too height tabular note to divide in 2
Hello !
I have a tabular note with 80 rows using a spreadsheet. As it is too high to enter in my drawing, I would like UniGraphics to divide it in 2 tabulars :
- the first with 50 rows
- the second with 30 rows.
Of course, if I increase the rows quantity to 84 , I would like UniGraphics adapt the 2 tabulars to 50 + 34.
Do you know how to do ?
Thanks for your support, Best regards !
RE: Too height tabular note to divide in 2
Here is how you can do this:
  • place a tabular note
  • right mouse button (RMB) click on palced tabular note and select Style
  • under Sections tab, define the maximum height for the table. You must find for yourself, how many lines are for example in height 100 (i think, there are 14 lines in height 100). But this shouldn't be a problem
  • under Sections tab, open the Growth section. If you want for example, that the next table is shown on the right of the original table, then select Right at Continuation Properties.
  • click OK to close the dialogbox
  • click again with RMB on the tabular note, but this time, select Cell Style
  • Click on Fit Methods tab and select Abbreviate
  • Click OK to close the dialogbox
Now, edit the tabular note with spreadsheet. As soon as your table exceeds the height, defined in Table Style, a new table will be created with additional lines.
Hello SvenBom !
Thank you very much for your explanation.
Because I'm working with UniGraphics 7.5.3.3 , I just needed to adapt the step 4 of you process by replacing "Growth" by "OVER FLOW".
And now every thing is working.
Thanks again.
Bye.
