How to read text file line by line using Solidworks API?
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim lines() As String = IO.File.ReadAllLines("C:\Users\hong\AppData\Local\Temporary Projects\WindowsApplication1\bin\Debug\1.txt")
Dim lineArray As New ArrayList()
Dim o, p, q, r, s As String
For x As Integer = 0 To lines.GetUpperBound(0)
lineArray.Add(lines(x))
Next
o = lineArray.Item(0)
p = lineArray.Item(1)
q = lineArray.Item(2)
r = lineArray.Item(3)
s = lineArray.Item(4)
MsgBox(o)
MsgBox(p)
MsgBox(q)
MsgBox(r)
MsgBox(s)
End Sub
Next
MsgBox(o)
MsgBox(p)
MsgBox(q)
MsgBox(r)
MsgBox(s)
End Sub
