VBA macro not saving
I did a search for this and I found 1 answer. It said to search for "UGII_SUPPORT_XLSM_SPREADSHEET" in the log file and change the setting. That's great but it's not in my log file! Any other ideas? My VBA macro keeps getting deleted in all my internal sheets every time I close the internal spread sheet.
Thanks!!
Thanks!!
RE: VBA macro not saving
thread561-324428: unigraphics NX unable to read data from excel file
If the environment variable doesn't show up in your ugii_env.dat file (not to be confused with your log file), you can add the line and save the file. Or, you can add it as an environment variable through Windows' control panel.
www.nxjournaling.com
Thanks!
This depends on how NX is administered where you are. Generally this file will be placed on a network location and all the workstations will look for this central file. If you are not the NX administrator at your site, you won't have the proper permissions to make it work. Contact the administrator with the variable name and value and they can get it to work properly.
What version of NX and Excel are you using?
