FEM-analysis using NX NASTRAN - Can't access results after solving .sim [NX 7.0]
Hello everyone,
So I am trying to perform a simple FEM analysis of a very simple disc using NX NASTRAN in the advanced simulation environment. I make a tetrahedal mesh, assign material, add a constrain for a fixed area and add a load. But when I solve the simulation, everything seems to be in order but there are no results I can access after I run the solver.
I have attached the files in question in a .zip archive including the .txt log of the operation. There are also some photos regarding what I mean.
It says completed, but obviously it didn't run everything it was supposed to.
There should be some Result tab appearing here.
Thanks in advance, I hope that someone can help me with this.
Best Regards,
Lars
Best Regards,
Lars
RE: FEM-analysis using NX NASTRAN - Can't access results after solving .sim [NX 7.0]
After finding this thread, I think this may be the problem.
I have to update my NX Nastran software as is experienced the famous April 1st, 2009 "Date Check" error.
But the link provided in that thread is expired. Can anyone provide where I can find this update?
Best Regards,
Lars
https://download.industrysoftware.automation.sieme...
Apparently though that only applied to NX6, so I think it must be something else.
I read the .f06 file that the solve produced and this is what it says:
CODE -->
*** USER FATAL MESSAGE 3060 (PREFACE) SUBROUTINE MODEL - OPTION NAST NOT IN APPROVED LIST. SYSTEM DATE (MM/DD/YY): 08/06/13 SYSTEM UGSID: 148798219 (DECIMAL) 08DE7B0B (HEXADECIMAL) SYSTEM MODEL NUMBER: 3 SYSTEM OS CODE: -1 SYSTEM UGSID: 1596055206 (DECIMAL) 5F21DEA6 (HEXADECIMAL) SYSTEM MODEL NUMBER: 4 SYSTEM OS CODE: -1 SYSTEM UGSID: 0 (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE: SYSTEM UGSID: (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE: SYSTEM UGSID: (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE: SYSTEM UGSID: (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE: SYSTEM UGSID: (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE: SYSTEM UGSID: (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE: REFER TO THE NX NASTRAN LOG FILE FOR DETAILED INFORMATION 1 * * * END OF JOB * * * *** USER WARNING MESSAGE 1152 (XCLNUP) SOME DBSETS IN THIS DATA BASE WERE NOT INITIALIZED COMPLETELY. USER INFORMATION: THE DATA BASE CREATED IN THIS RUN IS TOO IMMATURE TO BE RESTARTED. USER ACTION: DELETE THIS DATA BASE BEFORE STARTING YOUR NEXT RUN.RE: FEM-analysis using NX NASTRAN - Can't access results after solving .sim [NX 7.0]
You have a problem with your license, if you read the *.LOG file you will see the following:
CODE
Check the validity of your license.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
