Macro for making pictures WB
Hi fellows,
I Have this macro for making pictures in every substep in WB
!** OBRAZKY START **
/SHOW,PNG,,,8
PNGR,COMP,1,-1
PNGR,ORIENT,HORIZ
PNGR,COLOR,2
PNGR,TMOD,1
!rozliseni
/GFILE,800,
/CMAP,_TEMPCMAP_,CMP,,SAVE,
/RGB,INDEX,100,100,100,0
/RGB,INDEX,0,0,0,15
/CLABEL,1,0
/CONTOUR,1,16,AUTO,,
/DEVICE,VECTOR,0
/CTYPE,0
*GET,CumStep, ACTIVE, 0, SET, NSET
/title, Napeti krok: %CumStep%
*do,nn,1,CumStep,
SET,,,,,,,nn
/VIEW,1,1,1,1
/ANG,1
/EFACET,1
PLNSOL, S,INT, 0,1.0
*enddo
!** OBRAZKY KONEC **
/DELETE,_TEMPCMAP_,CMP
/SHOW,CLOSE
/DEVICE,VECTOR,0
Iw works, but the problem is that it makes ugly pictures with only 256 colors, is there some way to override 256 color issue? May be something with the „/ui,copy,save,png,graph,color,reverse,portrait,yes“ command? Or switching graphics device driver to „3D“. Thanks for replies :). Joey
