How to Get ObjectsHandler(NX Open) or Tags(Ufunc) of Objects created using Instance Geometry
Hi All,
I have created a Plane and then Instanced it Using GeomCopyBuilder class, now I want to get the Object Handler or Tags for the newly created Datum Planes. I have tried using GetBodies, Get Entities but it's not giving me anything...any help is appreciated...
RE: How to Get ObjectsHandler(NX Open) or Tags(Ufunc) of Objects created using Instance Geometry
Here is a bit of a round about method that might give you some ideas. Run this journal on an open part file, it will report all the features. Instanced features will have an asterisk in front and the tag will be reported.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim featArray() As Features.Feature = theSession.Parts.Work.Features.GetFeatures()
        Dim previousTimestamp As Integer = -1
        lw.WriteLine("*** All Features ***")
        For Each myFeature As Features.Feature In featArray
            lw.WriteLine("name: " & myFeature.GetFeatureName)
            lw.WriteLine("type: " & myFeature.FeatureType)
            lw.WriteLine("timestamp: " & myFeature.Timestamp)
            If myFeature.Timestamp = previousTimestamp Then
                If myFeature.FeatureType.ToString.ToUpper <> "CONTAINER" Then
                    lw.WriteLine("* instance feature tag: " & myFeature.Tag.ToString)
                End If
            End If
            previousTimestamp = myFeature.Timestamp
            lw.WriteLine("")
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
