Creating a top down mold design using Creo
I am trying to make a mold cavity using a contoured part to perform a Boolean subtraction for the cavity. This is fairly easily done using Component Operation -> Cut. However, I want all areas above the contoured part to be open, as if the bottom contour of the mold was fabbed by a 3axis CNC with a ball end mill. The only way I can figure out to do this is by patterning many copies of the contoured part along the z-axis, and then subtracting them from the mold. This works, but it is arduous and leaves scalloped edges. Any advice on how to easily make this feature?
-Dave
-Dave
RE: Creating a top down mold design using Creo
