Road Plate Design
Road Plate Design
Road Plate Design
I am looking to design a road plate to carry a point load right smack in the middle of it. The Road plate would be supported on all 4 sides, however i feel that assuming that the plate is only supported on two sides and would only be bending in one direction is very conservative. Does Anyone know where I can find a good source for road plate designs? Is there a manual or online source?
Thank you.
RE: Road Plate Design
First you need to define your loads. I am in Canada, I would use the Highway Bridge Design Code (CSA S6). I don't have the code in front of me, but there are a couple of different wheel loads to consider...depending on the size/orientation of your plate they may or may not be in combination with each other. Loads are something like 88 kN over an area of 610mm x 305mm or 25 kN over 305mm x 305mm. Then there are some load factors and dynamic load factors (1.7 and 2.0 I think). From there I would use Roark's Formulas for Stress and Strain to size the plate.
If you want a manual specific for road plates you might try searching NAVFAC for a design manual...they're full of useful information.
I would think the highway department or somebody already had tables of standard width/thickness for this kind of stuff.
From what i understand, it's almost always 3/4" thick. I don't know if they have plates they reuse but that thickness is typically enough. (Not that the numbers shouldn't be run on it though.)
Ask the firms that rent barricades, flashers and concrete barriers. They sometimes rent the road plates. Ask about their design process.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Thank Everyone! I found my answer from the last post.
