Determine vehicle electric load and amps used
Using which device or method, I could calculate and determine total electrical loads and amps used in a vehicle ?
RE: Determine vehicle electric load and amps used
http://www.sears.com/shc/s/p_10153_12605_034823690...
With all lights and accessories on, and the engine off, a clamp around a battery cable would indicate everything except the ignition etc and ECU.
Running, the big alterrnator wire might tell the tale.
