Macro to close spline in drafting
After defining spline points on a drawing, I right click on the spline, go to a sub menu and then check the "close spline" box. Easy but I am doing this a lot so I unsuccessfully attempted to record a macro. Any suggestions on how to accomplish this?
RE: Macro to close spline in drafting
Off the top of my head (don't have access to CATIA at the moment) I'm am fairly certain that it's impossible to do this via a macro given the API. However, I was trying to do it with splines in the sketcher workbench. Although I'm assuming that if a spline can't be closed via a macro in the sketcher workbench, then it can't be done in the drafting workbench either. I think you would need CAA.
Drew Mumaw
http://www.drewmumaw.com/
http://www.textsketcher.com/
