Looking for a Material That Will Displace Like Sand When Under Load
I'm looking for a durable material that can displace like sand when someone walks on it. I am considering closed-cell polyurethane foam. I would prefer to have a material that has small individual grains similar to sand but much lighter. If this isn't possible then a solid gel/foam material that has a large displacement when a force is applied might work well. Please let me know if you have any ideas.
Thanks.
Thanks.
RE: Looking for a Material That Will Displace Like Sand When Under Load
Chris DeArmitt
Expert consulting & training
www.phantomplastics.com
I also found a product at a dollar store that behaves kind of like what I'm looking for. It is essentially a stress ball filled with microbeads. I'm sure there are many different types for microbeads that can be used. Do you know the type of microbeads that are typically used in a stress ball application? Where might I be able to buy microbeads?
http://www.marblesthebrainstore.com/isoflex-stress...
You can still use sand. It's cheap and works great.
Chris DeArmitt - PhD FRSC
Materials Consulting & Training
