A problem I cannot understand - Revolved cut.
Hello.
I made a model of a link that is supposed to be a section of a chain. This part will be printed on the 3D printer.
I tried to make a revolved cut for a ball joint where another type of link will connect to this link.
(There will be links with balls on both ends and links that with receptacles for those balls.)
Something doesn't work out. Solidworks 2013 even generates me a nice rendering of how the cut will look like but than it gives an error message.
RE: A problem I cannot understand - Revolved cut.
2nd screen shot
3rd screen shot
Those images are for the post above and they depict a spherical cutout inside a cylindrical cutout that I tried to make.
Thank you.
Jeff Mirisola
My Blog
I cannot revolve a full circle 360 degrees. I can only revolve it 180 degrees so it wont pass over itself.
Timelord
Dan
www.eltronresearch.com
Dan's Blog
