Bolting connections to concrete reduction factors
When we have a group of anchors to concrete, do we typically applied the spacing reduction factor for each bolt around the bolt in question? For example:
If I have 5" spacing between three bolts, with a specing factor 0.75 for this spacing, then the capacity of the middle bolt would be = 0.75*0.75*(Unreduced capacity)... Is that correct?
RE: Bolting connections to concrete reduction factors
The capacity of the group X .75.
Mike McCann
MMC Engineering
