EPANET Pipe length scaling
Hi There,
I have inserted a correctly scaled backdrop map into my model and autolength is on. I drew in all my pipes to scale but all the pipes are still showing 1000 ft in length. is there a toggle switch I can use that will put the pipes to the correct scale.
RE: EPANET Pipe length scaling
Go to the tab: Project -> Defaults -> Properties -> Auto length
then turn it on.
I've notice that whenever you reopen EPAnet the default is set to Auto-Length Off. You can always easily see if it is on or off by looking at the bottom left corner of the program window. You can easily toggle on and off by clicking on the display in the bottom left corner.
