Journal for Save As in IGES Format
I need a journal to save as assembly files in IGES format in the working directory itself.
I tried to create one looking at some existing journals, but unable to complete my journal. I know nothing about computer languages, so I could be wrong at many or all points.
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim fileName As String = IO.Path.GetFileName(workPart.FullPath)
Dim fileNameNoExt As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
Dim parentFolder As String = IO.Path.GetDirectoryName(workPart.FullPath)
Dim root As String = IO.Path.GetPathRoot(workPart.FullPath)
Dim thepath As String = "fileNameNoExt: "
Dim PartExt As String = ".igs"
Dim displayPart As Part = theSession.Parts.Display
Dim partSaveStatus1 As PartSaveStatus
Try
partSaveStatus1 = workPart.SaveAs(thePath+displayPart.Leaf+PartExt)
partSaveStatus1.Dispose()
Catch ex As Exception
End Try
End Sub
End Module
However after running this journal, no error came but no file was created as well.
Thanks in advance,
Ishant
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Module NXJournal
Sub Main
Try
End Try
End Sub
End Module
Thanks in advance,
Ishant
RE: Journal for Save As in IGES Format
Try to change the line :
by this line :
partSaveStatus1 = workPart.SaveAs(IO.Path.GetDirectoryName(workPart.FullPath) & IO.Path.GetFileNameWithoutExtension(workPart.FullPath) & ".igs")
Thanks for your support!
to:
partSaveStatus1 = workPart.SaveAs(IO.Path.GetDirectoryName(workPart.FullPath) & "/" & IO.Path.GetFileNameWithoutExtension(workPart.FullPath) & ".igs")
Thanks for the help,
