Fabrication of CRA overlay welded pipeline for Sour services
Hi Fellows,
I have two questions regarding the CS pipeline overly with alloy 825 for sour services:
1.Do we need to use CS NACE comply material (HIC and SCC tested) for base material?
2. After alloy 825 weld overlay does the pipe need to be PWHT?
I did look on the NACE MR0175/ISO 15156 para A.2.1.5 and did not get a clear answer to my questions.
Any comment and clarification refering to NACE and experiances in the past appreciated.
RE: Fabrication of CRA overlay welded pipeline for Sour services
2. Refer to ISO 15156-3, A.13.1, paragraph 2
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Thanks for your post. Actually I was looking to have your interpretation regarding the necessity of NACE comply material where we are using weld overlay in sour services and moreover if stress relief is required for CS overly with alloy 625 for sour services.
NACE MR0175/ISO 1516 part 3 clause A.13.1, paragraph 2 is not clear enough.
Can you provide your interpretation for captioned para more in detail.
Stanweld
We are going to use alloy 625 for weld overlay and not alloy 825. Good point.
Steve Jones
Thanks for your comments.
Per the contract specifications, we field welded with E/ERNiCrMo-3 (I would have up-alloyed for the service). PWHT was not required by B31.3, the applicable Code. Base pipe material was seamless carbon steel. I did review the O.L. WPS of the fabricator and did have the contract specs for the pipe.
You need to look through clause 5.4,of API-5LD, 2009 for Heat Treatment. PWHT following CRA weld overlay could be asked by the client subject to base materials being used and design requirements . C.S pipes may be exempted from PWHT following weld overlay subject to project requirements.All testing (both mechanical and chemical) requirements are clearly specified in API-5LD and should be met.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario, Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
