Insulating flange kit
We are putting a low pressure fuel gas line in a power project that has sections of underground to aboveground and back to underground piping. Do we need insulating flange kit at these UG & AG locations mandatorily? Is there a ASME or other Code requirement that specifies this? Appreciate your inputs.
RE: Insulating flange kit
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
You need to determine if Cp is actually required or just make it quite thick ( if it's low pressure it probably is much thicker than it needs to be for the pressure alone) and coat and wrap it.
Steve Jones
Johan Sentjens
www.linkedin.com/in/johansentjens
Steve Jones
