cells referencing
cells referencing
I want to create a column of cells like following:
=M2
=M7
=M12
=M252
As you can see each of these =M references to a cell which comes after 5 cells of the previous one.
How can I do that without entering all these =M.. one by one?
Many Thanks
Alaa
=M2
=M7
=M12
=M252
Many Thanks
Alaa
RE: cells referencing
=OFFSET($M$2, 5*(ROW(M2)-ROW($M$2)), 0, 1, 1)
(2B)+(2B)' ?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Indirect would require you to populate additional cells with addresses (that will be accessed by indirect formula in another cell). Could accomplish the same thing but wouldn't be my personal choice.
(2B)+(2B)' ?
your formula worked well.
Many Thanks all
Alaa
Also I normally generate a column of index (or offset) numbers using a simple formula (=Cell above + 1), rather than using the Row function, just to keep things simple.
Just different ways of doing the same thing.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Best to you,
Goober Dave
