How much does water pressure vary for municipal water supplies? I'm in the state of Washington, USA
I've tried calling the city about this but I wasn't successful. I'll try again today and update.
RE: How much does water pressure vary for municipal water supplies? I'm in the state of Washington, USA
Independent events are seldomly independent.
"All water mains, including those not designed to provide fire protection, shall be sized after a hydraulic analysis based on flow demands and pressure requirements. The system shall be designed to maintain a minimum pressure of 20 psi (140 kPa) at ground level at all points in the distribution system under all conditions of flow. The normal working pressure in the distribution system shall be at least 35 psi (240 kPa) and should be approximately 60 to 80 psi (410 - 550 kPa) and not less than 35 psi (240 kPa)."
http://10statesstandards.com/waterrev2012.pdf
