Component Groups
Component Groups
I'm just starting to mess around with creating component groups in order to make large assemblies more manageable.
I have an assembly that has about 1500 fasteners in it, so I had the idea to create a component group of all fasteners so that I can toggle them on and off all at once. I also wanted to be able to close all those parts, then save a bookmark to make the assembly quicker to load the next time. However, when I right click on my fastener component group, and select components - close - part, the parts do not appear to be closed. In the assembly nav they are all greyed out, but the box is still checked. When I load my bookmark I also notice that those fasteners are showing up as loading in the status bar although they do not appear on the screen when the assembly finishes loading.
Anyone know what is going on here?
RE: Component Groups
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
As a follow on question, I notice when I right click on the component group - components - open, there are 3 options: Component, component fully and start part. What are the differences of these options?
Similarly for the close option there is part and part (modified). Why the 2 options?
Thanks for the help
The Component Open options, at least the first two, 'Component' and 'Component Fully', are the same as when you set the Load Options to either open Compoment Fully or not. When it's using the non-Fully option, only the geometric model is loaded but none of the non-geometric data, like the parametric structure and some other data not needed for most things that you do in the context of an assembly. As for the 'Start Part', I think it's related to using WAVE linked Assembly 'control structures', but I'll have to get some more details to fully explain how you would use this option.
As for the Component Close options, basically the normal 'Close Part' option will close all non-modified Components and leave the modified ones open even if they were members of the Component Group. The 'Close Part (Modified)' will force the closing of all Components, modified or otherwise.
Anyway, I'll try to get more details and get back to you if anything I learn changes my comments.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
