Opening NX8 files only in desktop
Hi friends
I tried to open a NX file (from his folder) in my hard disc , however the only way to open the files is copying or moving onto the desktop.
Some one of you identify this problem?
NOTE: All files were created in NX8
Thanks for your comments
Tom
Tom
NX 8.0.0.25 64bit Windows 7 Enterprise
RE: Opening NX8 files only in desktop
www.nxjournaling.com
Negative, not appears any message.
Tom
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for your comments, I applied the last option that you described "If not, you will need to browse to where NX is installed and select the UGRAF executable. And if you toggle ON the 'Always use the selected program to open this kind of file' option then this should work as expected in the future" and appears this error message.
Tom
Thanks for all of your contribution, I found the mistake, the problem was because the *.prt file was into many folders and one of them had a description whith letter ñ, that situation caused the error when it tried to open the file.
Johh, your comment was the clue for resolve this item.
Best regards
Tom
