conc. crack sealing
conc. crack sealing
I am looking for a product that can seal cracks, like an epoxy injection, that is also waterproof, but here's the kicker..........I'm looking for something with a high viscosity.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: conc. crack sealing
It does penetrate top surface cracks via gravity, but the depth of penetration is very dependent on the crack width and the cleanliness of the crack. It does NOT replace crack repair via epoxy pressure injection.
Equivalent products in BASF are Concresive 1320 / 1335 for wet cracks and Concresive 1315 for dry cracks.
Remember all these products can ONLY be injected and not just roller applied or painted on crack surface.
Decide which is more important and then select the proper material for the application. You might end up using two different materials, applied separately.
As hawkaz note, call Sika.
