How to collect an array part name
Hi I have some code and also I am new.I want to ask a questıon.The codes in below how can I get part name of product (ıt meanscurrent_prod.ReferenceProduct.Parent.Name) in an array?
Can you help me please?Thank you.
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
If InStr(CATIA.ActiveDocument.Name, ".CATProduct") < 1 Then
MsgBox "Active CATIA Document is not a Product. Open a Product file and run this script again.", , msgboxtext
Exit Sub
End If
Call ListingNames(productDocument1.Product)
End Sub
Sub ListingNames(current_prod)
Dim partName As String
partName = InputBox("Please Enter the Filename")
If current_prod.Products.Count > 0 Then
For i = 1 To current_prod.Products.Count
Call ListingNames(current_prod.Products.Item(i))
'MsgBox current_prod.Products.Item(i).Name
Next i
Else
If partName = current_prod.ReferenceProduct.Parent.Name Then
MsgBox "succesful"
Else
MsgBox "try again"
End If
MsgBox current_prod.ReferenceProduct.Parent.Name
End If
End Sub
RE: How to collect an array part name
This might help you
CODE --> VBA
Sub CATMain()
    Dim productdocument1 As ProductDocument
    Set productdocument1 = CATIA.ActiveDocument
    Exit Sub
    End If
    MsgBox productdocument1.Product.Products.Item(1).Name
    MsgBox productdocument1.Product.Products.Item(1).PartNumber
    MsgBox productdocument1.Product.Products.Item(1).ReferenceProduct.Parent.Name
End Sub
Sorry but it doesnt work , this method supplied to find coordinate system part.For example my product's first partname is product start part "Product Start CS.CATPart".This method returns "Product Start CS.1 " and so ıt does not work.I wan to say again ,when I enter into what I want to part name in "Inputbox" and if programme find it in subpart it should be returned by MessageBox.As a result I want to put into array whole subPartNames then according to "if statement" I wan to find before inputbox part name.
for example, inputbox-- partName = InputBox("Please Enter the part name")
(I wrote 1234.CATPart)
'In here "current_prod.ReferenceProduct.Parent.Name" is put in array How???
'and then
For i=1 To current_prod.Products.Count
if partName=myArray(i)
MsgBox "This your your part name: " &partName
thank you
Here you are but myCount gives error unfortuantely.
Sub CATMain()
Exit Sub
End If
End Sub
Dim myCount As Integer
myCount = 0
Dim myArray(myCount) As String
If current_prod.Products.count > 0 Then
For i = 1 To current_prod.Products.count
myCount = myCount + 1
Next i
Else
For j = 0 To myArray.Lenght - 1
myArray(j) = current_prod.ReferenceProduct.Parent.Name
If partName = myArray(j) Then
MsgBox "Your part is found: " & partName
Else
'MsgBox "try again"
End If
Next j
End If
End Sub
CODE --> VBA
Option Explicit
Dim strSearch As String
Dim PartFound As Boolean
'Dim MySelection As Selection
Sub CATMain()
    Dim MyDoc As Document
    Dim MyProduct As Product
    Set MyDoc = CATIA.ActiveDocument
    Set MyProduct = MyDoc.Product
    'Set MySelection = MyDoc.Selection
    strSearch = InputBox("Input Search String")
    PartFound = False
    If strSearch = "" Then
        MsgBox "Search String is Empty", vbExclamation, "Error"
        End
    End If
    Call Traverse(MyProduct)
    If PartFound = True Then
        MsgBox "Part Found", vbInformation, "Success"
    Else
        MsgBox "Part Not Found", vbExclamation, "Fail"
    End If
End Sub
Sub Traverse(MyProduct As Product)
    Dim i As Integer
    Dim PartName As String
        Exit Sub
    End If
    For i = 1 To MyProduct.Products.Count
        If MyProduct.Products.Item(i).Products.Count = 0 Then
            PartName = MyProduct.Products.Item(i).ReferenceProduct.Parent.Name
            If PartName = strSearch Then
                PartFound = True
                Set MySelection = MyProduct.Parent.Selection
                MySelection.Clear
                MySelection.Add MyProduct.Products.Item(i)
                CATIA.StartCommand "center graph"
                CATIA.StartCommand "reframe on"
            End If
        Else
            Call Traverse(MyProduct.Products.Item(i).ReferenceProduct)
        End If
    Next
End Sub
Thank you jagandeep really!You know I am a student and I was thinking to give up because of hopeless.You gave dare me.
Maybe you can think about greedy please not,but how can I use this part information to reach position ,translation ,rotation values about interfaces?If you are busy you can give just one sample for example just rotation and I can research other topic.Otherwise I can produce idea logicly about other topic.I hope all is well!
Welcome Dear
Thank you dear jagandeep.
