Toe-Screwing Joist to Girder
I have a client who asked me to review his arbor strucure. The structure is simply cantilevered wood columns supporting 2x8 girders that go around (4) sides.....that in turn, support 2x8 joist members at 16" o.c. There is no plywood or anything like that on this arbor.....this is simply an aestetic structure....intended to provide some degree of shade over an eating area.
The typical 2x8 joists are notched on their bottom by 1 1/2" as they cross over the top of the supporting 2x8 girder (the girder is let-into the bottom of each joist by 1 1/2"). The client does not want visible joist hurricane anchors to foul the appearance of the arbor. In order to make a positive uplift restraint connection, I am going to have to use wood screws at an angle (toe-screwing).
I was thinking of predrilling the holes from each side of each joist and toe-screwing down, thru the joist, into the girder below, from each side of each joist, with each screw embeded 2 1/2" into the girder below (starting about 1 1/2" up off the bottom of notched joist. I am not worried about rotation of each joist, as each joist is extensively laterally braced via blocking at 24" o.c.
I typically to not "toe-screw" in this fashion. I typically use Simpson uplift anchors 99% of the time.....but in this case, I can not. Are there any pitfalls to the use of toe-screwing thru pre-drilled holes that I should be aware of?
RE: Toe-Screwing Joist to Girder
Mike McCann
MMC Engineering
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
There is a very good chance that the angle you choose to drill at is going to be in line with the growth rings of the lumber due to the way it's cut. It's very weak. Even pre drilled there is the possibility of the wood splitting as soon as or shortly after the screw head makes contact. Whether it splits or not it's going to be a pretty weak connection. With that said, you would need have an idea of how much uplift it could possibly see to determine what is required to hold it down.
BA
