Mounting 600 grams of Aluminium around a spindle of a CNC machine
I am trying to mount a circular clamping brackets made of aluminium around a drilling CNC machine spindle , the total weight of the clamping brackets is around 600 grams,I will perform some drilling tests but I am worried that the centrifugal forces made adding this weight on the spindle will cause a lot of vibration and out of axis rotations and hence the drilled holes will be very poor
I was wondering if anyone have tried to mount something on the rotating spindle before or anything similar to what I am planning to do.
Thank you all
RE: Mounting 600 grams of Aluminium around a spindle of a CNC machine
It all depends on if it is a balanced or an unbalanced load. You will have a greater starting load, but the spindle will have more inertia, as well.
I'd include a dense circular pattern of drilled and tapped holes for setscrews to be used as trim balance weights.
http://www.singahobby.com/files/images/Vess-100CC-...
Axially drilled holes are considered safer than radially drilled holes.
If the OD and faces run very true ( 0.0001 inch or so) to the ID, and the corresponding spindle diameter runs very true a homogenous part would have pretty good balance. Assymetrical modifications and features to provide clamping (slots, tapped holes, screws/bolts) will be a bigger source of unbalance.
Good idea Moose. I remember in the VERY early days of hard drives (12" platters!) that CDC used radial Nylock setscrews as balance weights. They could get a rough balance by putting one or more into selected radial holes and then by screwing then in or out of the holes they could dial in a precise balance.
