Pump keeps kicking out
Hi
I work in pulp and paper and am troubleshooting a pump. It is a centrifugal pump 9" impeller (goulds 3196mtx); motor 3HP, 1760RPM, 3phase constant speed induction motor, 575V, 3.2A. The flow rate we are putting out is 23gpm. The motor is the right size for application (meets the pump curves)
The problem is the motor keeps kicking out. It is pumping polysulfides orange liquor (pulp and paper jargon). We think it is scale build up in the pump that is causing the motor to trip.We do an acid wash once a year right now. It is a time intensive process and increasing the frequency is a bit difficult. Putting in a bigger motor seems unreasonable as we don't know if the amps drawn by the motor ever level out.
Any pumps out there in the market which decrease the rate of scale build up.
Or maybe there is some other reason for the kick outs.
Naqshe Iqbal E.I.T
Naqshe Iqbal E.I.T
RE: Pump keeps kicking out
Has the liquor SG been factored into the power calculation?
What is the liquor temperature?
At the flow rate we have and with the S.G factored in (viscocity was very similar to water)the pump shouldnt require more than 2.5HP.
We cant open the pump for sometime. It is important for production.
Is the voltage at the motor terminals low? Induction motors, over a limited range, behave as relatively constant power devices, meaning that a slightly low voltage will result in more current being drawn.
The actual current varies.The current drawn is constantly increasing from the time of a kick out to the next kick out. The overloads are currently set to 110% of 3.72A. They are in a relatively cool room; the room has mcc for other motors with no isses. Voltage is never below 575V.
We checked the RPM of the motor once and found when the motor was drawing more current the RPM were lower than full load RPM of the motor (more slip) showing that there was more load on the motor.
What is interesting is that right after a kick out the amps drawn are actually lower than what was being drawn before kick-out and then they gradually rise till kick out (constant flow rate).
Something to do with a kind of rheological time dependent behavior of the fluid. The longer the fluid undergoes shearing force, the higher its viscosity. So the longer the fluid is flowing in the pump and the pipes (shearing effect) the viscosity keep on increasing.
When the motor kicks out, the fluid property are reset, thus the viscosity.
On restart, the power required on the motor returns to its origin value.
It the fluid pumped in a closed loop ?
It's clear your pump is demanding more power form the motor. This can only really come about due to increased density compared to the deisgn over time, increased flow?, increased head differential or decreased efficieny (your scaling).
However if it "resets" between trips it's difficult to see how scaling can do this.
As with many pump "problems", in reality it's the system that is the problem, so watch the critical things over time (differential preessure, flow rate, density) to see if they change. Even a relatively small change or the fact that your pump is actually putting out a greater head or lower efficiency than you think can easily eat into your relatively samll margin of pump shaft power vs motor output power.
As ever, a flow diagram or sketch of the system, the pump curve, the system curve etc all helps us to understand your system and point out potential issues much easier than words, though figures and data always help...
I'd guess that once there is a drop in speed for whatever reason (change in conditions that cause a brief increase in flow, therefore power?) the motor can't quite manage to accelerate back up to "full speed" so instead it trips. Almost like the motor is repeatedly experiencing the tail end of a warm start, until it gives up and trips.
The flow rate is 23gpm. It varies very little, there is a throttling valve controlling the flow rate from the pump to maintain certain level in the tank. The maximum I have ever seen it increase to is 26gpm but that was just once. When the motor trips the flow rate is around 23gpm. So it is not an increase in flow rate causing that.
S.G of the fluid is 1.17. Viscocity is very close to water.
It is pumping out 96ft of head, incoming head is not even half a foot.
Pump curve.
http://i43.tinypic.com/mj1tw6.png
I am guessing that your loses go up as pipes have buildup in them. Also the elevation head is only 32ft but it takes a long path.
From the pump curve motor shouldn't be demanding more than 3HP at CURRENT settings.
As for reseting i was thinking that maybe the flow of liquid through pump kind of dislodges it.
Right now I am open to any reasonable suggestion.
First, Your point is at 23 gpm and a BEP at around 70 gpm at constant curve from the graph.
This is the first abnormal observation.
Second, you have poor reserve margin with a 3HP motor since the iso-power line is very close and it limit completely your map. It does not even allow you to move to the right of the curve. In case of flow fluctuations (system curve with slightly less resistance) you trip the motor.
If the motor is really rated 3HP than it is undersized and the furthermore (which may be at the root of poor motor sizing) the operation is not in the safe area of the map. In fact this is the problem not the Motor itself.
Your generic pump curve will be based on water. For shaft power you need to work on multiplying the power by 1.17, so gets you much closer to 3HP. An earlier post said you hasd allowed for that, but this curve says it hasn't. It is also a generic curve, not a specific as tested one so you could easily be + 10 to 15% more power requirment as most suppliers tend to allow for a bit of wear and know that people tend to complain when they don't get enough flow / pressure, but are usually quite happy with a bit more. Also you're working so far on the LHS of the pump curve the efficiency lines are actually pretty vague and all sorts of odd things start happening inside the pump at reduced flow compared to it's BEP to increase power requirments.
I can only assume you are working in US GPM. If either of your flows is in imperial it will add another factor.
Basically your pump is underpowered and as the motor warms up seems to loose the sysnchrous speed which is just going to drag the power up and lead to overload.
If you can stick in a 5 HP motor all your problems may go away or better still swap the pump for one which has a duty point (BEP) much closer to your 23gpm.
Pump power required = (Flow rate (GPM)* Head (ft)* Specific Gravity )/(3960*Efficiency) =(23 (GPM)* 96 (ft)* 1.17 )/(3960*0.26) = 2.5HP
I agree, we are operating in a very inefficient area of the curve.
I don't think it is fluctuations of the flow that are causing the motor to trip. What we see is even if the flow rate is relatively contant the amps drawn rise steadily. We have taken ammeter readings over a period of 4-5 days. The motor tripped three times during that period and after a trip the amps drawn will decrease a little bit and hten steadily rise till the motor trips again.
We were thinking of the same thing. But we don't know what are the max amps drawn by the motor at nominal flow rate. 5 hp might kick out later than 3hp but we cant guarantee it wont.
This is bad design because as it cannot be an unexpected off design or even an oversizing on purpose since the motor has been rated on this point i.e. 23 gpm ; apart if the motor was intended to be replaced on purpose as part of a future revamp.
You say you agree your pumps operates on a poor efficiency area but that is not quite the point. The point is you will end up with mechanical issues with your pump. No need to discuss the flow fluctuations story. The point is completely in the left corner of the map. Unless you run with some funny pump and impeller (you should tell us if it is so) there is NO justification for this design for any conventional single or multiple stage pump. Anyway the iso efficiencies speak for themselves.
Furthermore I disagree on your point related on the stability of the flow. All it takes is a small excursion or upset in your process to start running the 3HP motor on what should be (at least) a power reserve. You are looking at second order issues to explain a situation which is primarily improper design.
The motor rating you mention in the Original post is 3HP, it should be mentioned anyway on the Nameplate.
quote
... You should get a bigger motor (maybe pump too)...
unquote
not quite correct:
pump is too big.
motor is too small.
We have overloads at 4.10amps for a motor with fla of 3.2Amps.
It trips becasue it is drawings more amps than it should. According to ammeter reading that can be from 4.1 to 4.2 amps
There could be some fouling issue as the flow is so low compared to what it is designed for so I would go for a properly sized pump as your main resolution issue. Short term, not much I can think of, but clean the motor fins, make sure the motor fan is clean and not deformed, or maybe remove the motor fan and use an external bigger fan to give the motor output that little bit more power, check the stuffing box and lubricate the bearings. Every little thing will help.
Has the flowrate, total head, and SG been measured?????? - or is it a guess or your expectations.
looking at your pump curve the pump should have been fitted with a 5hp motor to make it non-overloading across the full pump curve.
The selection of 26% for your efficiency may well be wishful thinking, operating where you are on the curve so far left of BEP the real efficiency could be anything other than 26% probably a lot less, unless you have ideal inlet conditions to the impeller which is unlikely. Bear in mind this curve was produced in an accurate test facility, something you can't reproduce on site without accurate and correctly placed certified gauges and flow measuring equipment.
I also think that saying the pump is definitely pumping 23 GPM at 96ft at a constant 1.17 SG at 26% efficiency is also wishful thinking and not actual operating conditions.
For instance, if the flow is 25GPM head 97, SG 1.2, efficiency 24 then power requirement is above 3hp.
The impeller is 9" (physically checked), S.G also checked.
Flow rate is 23gpm (nominal doesn't fluctuate much).
We just opened the pump and found very little scale build-up. The impeller was not rubbing against scale in the housing.
I agree the pump needs more power. But why are the amps drawn constantly rising. We see amps increasing and not a steady draw of amps.
The motor has so poor margin that the load impact directly the slip.
The speed reduces and so the speed of the pump and the head, therefore the flow decreases further and the efficiency drops. The efficiency drops imply again more load on the motor and slip increase again.
and so forth till you trip the motor.
does this make some sense ?
- you mention throttling valve. Is it automatically controlled ? If so give us the percentage of opening versus time from one trip to the other.
- Do you have some monitoring of the speed of the pump ? if so give us the speed evolution with the time from one trip to the next one.
- Please provide the percentage of increase in current from min to max
- How much time it takes from one trip to the next. Is it in the range of magnitude of the time needed for the motor to cool down? You mentioned constraint to keep the production so how long you keep up continuous operation until the trip.
- What type of intervention on the motor do you perform after trip. Let the motor cool down and restart, make replacement of thermal switches or whatsoever ?
- Do you monitor the suction, discharge pressure and flow somewhere in the process ? if so please give us the trend vs. time
- Can you arrange and monitor the temperature in the motor winding or somewhere to see the trend ? is the room temperature stable what are the % expected variations ranges ?
These are a lot of info. but the more we get, the better.
It responds to the level of the tank pump is sucking from. pneumatic control valve.
That will be a bit hard to do. But I can confirm that when the motor os drawing more amps the motor rpm is lower than full load rpm
2.7- 4.3 (trips)
Time varies between trips. Sometime it wouldn't trip for days.Sometimes it will trip 2-3 times in a day.
Just reset overloads.
What I was wondering if heating of motor can result in larger amps drawn?
Also we opened the pump up and found barely any scale on it. There was some scale on the control valve. Now that we have put everything together the amps drawn have dropped to 2.7amps from 3.9-4amps. So I was thinking that maybe something to do with control valve as the pump was clean.
total head reduces? Can you please elaborate on that.
Also I am trying to understand what happens to the fluid around control valve and how it affects the fluid in the pump. Just in a normal application. For example, if the pressure drop across the control valve increases how does it affect the fluid before the pump.
I know that pressure after the control valve is lower than before and the flow rate is same.
I see that it trips regularly and you have to reset and create outage to your process.
That will troubleshoot the problem. Moreover there is a consensus here that you motor is undersized.
That means your system is not robust to fluctuations in the whole system. Would n't this a better approach then inspecting components.
There might be a chance that the fluctuations are inherent to the big system and not necessarly a malfunction somewhere, in such case you would have wasted time and money possibly.
Since there was already an apparent choice to waste significant power by sizing the pump to operate inefficiently, it appears that operating energy costs are not a matter of much concern. It seems likely that a 5 HP motor may be enough to fix the problem, but I suspect that there may system operating characteristics that may present themselves after a change to a 5 HP motor. Because of the unfavorable pump selection, I would not be surprised that you may find operating conditions may develop where the 5 HP motor could be overloaded as the pump duty shifts into even less favorable efficiency ranges. I would seriously consider installing an even larger motor to avoid the need to make yet another replacement when other troubles show up. The difference in operating costs will be relatively trivial.
If operating costs were to be considered realistically, including the costs of troublesome interruptions, you may find that replacement of this pump with a properly chosen one may have a surprisingly short payback time.
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
With regard to efficiencies it does not seem to be an issue. Because if you look to the map w, the isopower lines decrease in power value with the lower efficiencies. in reverse, if the flow moves to higher efficiency (toward the BEP), the Isopower lines increase in power which could become an issue for the motor. This 5HP shoud cover the end of curve in anticipation of system curve change.
So if the fluid properties are constant, as it is said, that should be fine BUT we have to keep in mind that if the duty remains more or less around the specified flow, the motor will be partialy loaded (around 50-60%).
Thermal Factors
The increase in temperature of the liquid within the pump is directly
related to the pump’s efficiency. The energy that is available to heat the flowing liquid and the pump casing is basically the difference between the power input to the pump (brake horsepower) and the useful work done by the pump (liquid horsepower). At low flow conditions, centrifugal pumps are very inefficient and a significant amount of input energy is lost and heats the liquid and the pump assembly. Refer to Subsection 2.3.1 and Chapter 12 for more discussion on thermal effects.
You are correct. At low flow rates, pumps become very expensive "mechanical water heaters" to the point at zero or near zero flow they can even become even more expensive " mechanical steam generators."
rotaryworld,
My expectations about the 5 HP motor are that it will probably work, but I suspect that there may be unknown process fluctuations that may involve changes in the pumped fluid where density or viscosity may change to shift power demands beyond the 5 HP motor. The cost differences between a 5 HP or a larger motor are probably trivial compared to having operations disrupted yet again for the lack of enough power to get through an "excursion." As is so commonly the real situation, the claimed pump problems are actually some combination of system or pump selection problems.
I've known of "successful" cases where much larger and more powerful pumps have spent their entire operating lives at well below their BEP, but various compelling reasons made this the least costly alternative even when their seemingly excessive repair and energy costs were taken into consideration. In these cases the pumped fluid was just water, so no goofy business of varying composition, viscosity, or density introduced compounding complications.
I fully adhere to your approach.
With regard to running the motor at part load, what is your feeling about it ?
On the other hand, if we were discussing a 2000kW re-circ pump then we could have reasonable discussion on hydraulic efficiency or lack there-of so, lets get back to reality, it's the wrong pump for the application as well as being under powered for the situation it is in and if the OP can't see or doesn't want to see or accept this fact, then we are all spinning wheels discussing ideal applications, pump selection, hydraulics and theory as none of it will solve his problem.
We never know the economic rational of this plant, neither the financials behind and less the minset of the operator/owner.
It might be that owner is private (investing his own money to the last cent) who must operate with low cost imperatives.
Who knows that for him replacing a motor would appear or turnout to be something non negligible.
I personally doubt, but you never know.
We should check for and
eradicate any possibility of physical obstructing material
as if being sucked-in at random intervals
thus affecting pump out operations with increased E/power demand.
Best Regards
Qalander(Chem)
I have nothing against putting a bigger motor. I am only worried that it will start kicking out too as we dont know the max horsepower needed.
You know the max shaft HP of the pump - the issue is the max shaft HP of the motor is far too close or under this maximum demand. Double or triple the motor size and you are very unlikely to have this occur again. Get the right sized pump and the max power will decrease so you won't need to change cbale sizes or motro starter etc.
I would be very interested to see what the winding tmeperature rise is during these outages either from internal thermocouples or an external casing temperature. may give you a better explaaination...
Is there anything that can be done to reduce scale build up. We were thinking of a coating but are worried it will chip and enter our pulp stream. Can we use special impeller type that scrapes? Or any other solution.
Problem is not not enough power.
So what is happening now, why have you now asked how to reduce scale build up?
You will need to talk with a slurry pump manufacturer and ask their advice.
Given you have a control valve on level control, the loss of a few feet of head shouldn't make any real difference.
Scale is the only possibility I can think of. After acid wash amps go down, after flushing the pump with water amps go down.
As for rubber pump, or a coating we are worried it will chip off and enter our pulp stream.
I was thinking of an impeller with a scraper vane on it. That might prevent buildup.
Increasing the flow will increase the efficiency, but might not help with scaling. Or maybe more fluid will prevent scale build up. Will try that.
Let us know if it helps.
