Incident sound intensity on a infinite rigid wall with an opening
Dear all,
I have a question which is a bit general acoustics, but definitely something for mechanical engineers with a heart for acoustics.
My question is whether it is logic that a plane wave, incident from an infinite air medium onto a rigid wall with an opening of 1.5m by 1m (nothing is in the opening, after the opening there is a again an infinite air medium - rigid wall separates the full space), results in a non-constant incident intensity level curve measured and averaged over the opening. I am wondering some time now why this is not constant? I thougth that the intensity and power in a plane wave are constant i.e. that is what I understood from my acoustics class.
The non-constant intensity profile is as follows : a constant intensity level of around 55dB for plane waves from 10 - 70Hz. Around 80Hz a sudden increase happens in the intensity values till around 100 Hz till a level of 85dB is reached. Hereafter the 85 dB remains more or less constant till 1000 Hz. For these simulations a 1Pa amplitude pressure sine waves is taken for the whole frequency range.
I would be very grateful I someone could give me more insight why this is so,....
Thank you very much,
Mary
RE: Incident sound intensity on a infinite rigid wall with an opening
At 10 Hz the wavelength is 30 m and a 1m hole looks like a point source. At 1000 Hz the wavelength is 30cm and a 1 m hole looks like a very complex set of sources.
Cheers
Greg Locock
I think the point is that once your plane wave has hit the opening, it is no longer a plane wave.
- Steve
The "cut-off" wavelength of an opening is not a binary thing. Most gap attenuators in the RF will still propagate below the cut-off, just not as much. I would assume that even though the gap is 30x smaller than the opening, this just means that that opening is propagating ~30x less than if the opening were larger than the wavelength.
TTFN
Just a nit pick. How can 30x anything be less? Do you mean 1/30?
Ted
