PREHEAT & PWHT
PREHEAT & PWHT
HELLO ,
I want to know, for what basis PREHEAT & PWHT have to select for the weld joints????, ( i know based on the thickness of the base metal ) any other reason to select PREHHEAT & PWHT?
RE: PREHEAT & PWHT
When dealing with high % Ni, martensitic, chromoly, ... steels, you should study each case to see what the metallurgical consequences are.
PWHT is also used to alter the inner structure of the steels, in case you could end up with a less desirable microstructure.
I suggest you ask either specific questions or read up (a lot) about this, as this is not something one can cover in an internet thread (it took me a certain % of two years at school, there's more to it than meets the eye - literally)...
RE: PREHEAT & PWHT
if the carbon equalent is more than 0.55, do i need to do preheat?.
RE: PREHEAT & PWHT
Either way, I'm inclined to say yes (you need preheat), but without the steel grade, the product you're welding, ... and such this is merely a wide guess. Nevermind how to determine how much preheat you need... What does your buyer ask from you? PQR/WPS? nothing?
RE: PREHEAT & PWHT
Re. 0.55 C.E., it depends on thickness of the material, the ambient temperature & welding process.
RE: PREHEAT & PWHT
From this and other posts it appears you have been thrown into the deep end of the weld pool by your boss, who doesn't recognize the value of welding specialists. I'm not criticizing your efforts but these forums will be an inefficient and slow way of learning welding engineering fundamentals.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
RE: PREHEAT & PWHT
http://www.weldinguide.com/gdanastasiadis/viewtopi...
