SAME HEAT.. DIFFERENT CHEMISTRY
I have a case where there are two bolts
1. one is 12M-1.75*45mm
and 2. another one is 12M-1.75*35mm
1.75 is thread
12M is bolt size
45 and 35 is bolt length.
Now the supplier has provided MTC for both with the same heat number but different chemical properties...
Is this possible??
1.75 is thread
12M is bolt size
Is this possible??
RE: SAME HEAT.. DIFFERENT CHEMISTRY
How different are the chemistries, and what elements are different?
Are they both "in spec", but just a bit different?
Is there any reason to expect that all of the screws came from the same wire, or even the same batch of wire?
It seems entirely possible that - rightly or wrongly - they decided that these two bolt sizes were "close enough" that they could be run through the oven together.
See Tip #7: http://www.heat-treat-doctor.com/documents/Fastene...
I have attached the MTC Copy for your reference, please suggest ur opinion now
Please review and comment.
MNT
rp
Look at dates, certificate numbers, order numbers.
Also, the sizes listed on the certs do not match the sizes stated in your first post.
Lot size is listed as 50,000 parts. How many parts were tested? One of each? That's pointless.
While it is possible you are looking at a "fabricated" certificate, it is equally likely (or perhaps even more likely) that we are looking just at a clerical error. A little more research would be needed to determine whether or not fraud is at the root.
Please, contact the supplier for an explanation. Then, you can formulate an opinion on whether or not the information on the certificate is intentionally falsafied or not.
rp
Best regards - Al
That's something in excess of 11,000 kg of steel.
And from all of that there were TWO bolts tested.
It doesn't matter if these certs are legitimate or forged. They are worthless.
If the pouring is carried out in diffreent slab, then due to delay in pouring there may be chances for chemistry change (Minor).
I have witnessed this situation..
Aakash Jha
