How to setup rigid outriggers
Hi all,
I'm new to using SAP2000. I have experience with other (mostly in-house) FE software. I now need to model a really long steel beam (56 meters) which is being lifted at each end. A big concern is lateral torsional buckling. Normally this would not be a problem and analytical/empirical solutions in articles would cover this situation, but I am not quite sure if any particular situation in literature addresses this. So we have decided to use and FE model for this. I have modelled the beam using shell elements as well as the lifting brackets on each end using frame elements. I've included the cable elements as well. The problem I am having is how to model the rigid links between the beam and the end brackets and the end bracket and the cables (see pictures attached). I have attached my SAP model for review. I have tried constraints and link elements, but for some reason I am getting huge deformations in these elements. I have even tried to use dummy elements but no matter how rigid I make it, it seems to make no difference.
Any help is greatly appreciated.
Al
Al
RE: How to setup rigid outriggers
Longer beams have been designed for LTB using standard code equations.
I think you should try Ansys if you are really into buckling analysis. SAP2000 is fine with elastic critical buckling of frame elements, but I am not sure it will catch LTB.
hope this helps
