A question about fluid flow and balance
We manufacture plating barrels and have a customer that wants us to apply our SprayThru system to one of their barrels for testing. They will manually connect a hose from the pump to the quick connection on the side of the barrel.
I need to know how to be able to assure them that the flow through all four of the same size nozzles with be similar in spite of the fact that two will be 10” below the solution level of the tank containing the plating barrel and the other two will be 27” below the solution level. The total solution depth is about 45”.
All four of the nozzles have a flow rate 15.9 GPM at 40 PSI. They will be using a 5 HP pump rated at 80 GPM. The pump will send liquid through a 1-1/2" test piping to a manifold that will supply four 3/4" hoses routed to the individual nozzles. There is a drawing attached. As can be seen, the solution will flow through the manifold and down to the nozzles.
The hoses to the two upper nozzles are each about 7" long, and the hoses to the lower nozzles are each about 24" long.
Of course if the four nozzles will not be balanced, what do we do to balance them?
If the testing proves successful, they want to convert ten more barrels. These will have a manifold at the bottom sending solution up to the nozzles. The manifold will set down on a ball connector also supplied by 1-1/2" piping. Will the difference in flow direction affect the flow?
Please let me know if there is any more info that is needed to help answer this question.
RE: A question about fluid flow and balance
If you need little accuracy then restrictive orifices should suffice as long as the pressure drop across the orifice is large compared to all other pressure drops. Operating an 80 gpm pump at 16 gpm is not usually a good idea.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
Sorry for the confusion!
