Light Single Pass Vibratory Plate Compactor
Just wondering what y'all specify (or use if construction) for loose lift thickness for light weight single pass vibrating place compactor. See picture attached - it is a very light one . . . Appreciate any feedback . . .
RE: Light Single Pass Vibratory Plate Compactor
That looks like a typical vibratory compactor that is used for sidewalks, driveways and small areas around structures - They are proven and can be used on up to 6" lifts, depending on the material. I don't know what you mean by single pass since multiple passes are common since they almost float and can be worked in all directions.
They are also used on large and small paving stone installations for the upper base preparation and final vibration/truing up of the pavers to obtain a granular interlock necessary on all size projects. - It looks very strange to see a walk-behind plate vibrator used on a 30 acre heavy duty industrial (ship unloading) area, but they are effective and avoid the deep vibration that can be disruptive in low areas with a high water table or unstable soils.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
unsure from that picture whether ive just been hooked on a comedy fishing line or its a serious request?!
I think from the description they mean single direction rather than single pass. The smaller plate compactors are single direction while the better ones are reversible.
