cooling of a gaseus mixture of water and hydrocarbons
Hi there !
I'd like to ask you some help in a very specific topic that at the moment I don't know how to approach.
following is the topic
I have to realize a module to calculate a cooler of a mixture of hydrocarbons, water and gases.
During the process, there is a partial condensation of water and hydrocarbons, likely the heavier ones.
I am completely in the dark.
Please can anyone give me any suggestion, or suggesting me some correlations ?
Thanks !!!
Thanks !!!
RE: cooling of a gaseus mixture of water and hydrocarbons
Summing the energy traverses would tell you how much energy you must remove to reach the target temperature (you didn't really say what the goal of the exercise was, so I'm assuming cooler sizing).
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
Good luck,
Latexman
