Calculating shear strain along a shaft
Trying to calculate the strain at different points along a solid rotating shaft from an engine connected to a dynomometer. Need to find out where the maximum and minimum would be to help place strain gauges. Dimension L=576mm R = 50mm with a Max Torque from the engine being 767.4Nm and average Torque 170.8Nmm. Or even if there is a rule of thumb on where to place strain gauges but would be good to know strain values so we can compare gauge positions.
Any advice would be much appreciated.
RE: Calculating shear strain along a shaft
Try this site:- http://www.omega.co.uk/FAQ/Pressure/pdf/positionin...
