Does anyone know the best way to rotate a fiber optic joint on a vibration/shaker table?
Does anyone know the best way to rotate a fiber optic joint on a vibration/shaker table? Thank you in advance for your assistance.
RE: Does anyone know the best way to rotate a fiber optic joint on a vibration/shaker table?
Thank you for your response. I will be conducting vibration/shock/temp testing at a certified lab and need to mount my fiber optic rotary joint to the table (easy) and rotate it as the tests are being conducted (challenging). Do you know the best way to rotate the fiber optic rotary joint as the vibration and shock tests are being conducted?
