316L Stainless Steel in Hydrogen
Is 316L stainless steel subject to Hydrogen embrittlement if exposed to hydrogen gas at 75-85F for 18 hours?
Thank You.
RE: 316L Stainless Steel in Hydrogen
No.
HE requires mono-atomic hydrogen, not hydrogen gas. So if because of electrolysis, chemical reaction, or active corrosion there is a source you then need to think about HE.
In austenitic SS you only need to to worry if you have welds that have not been annealed and have high residual ferrite content they could suffer HE.
Plymouth Tube
Definitely no, irrespective of the condition of your welds. At those temperatures, for such a duration, even carbon steel would be OK, even at very high hydrogen partial pressures.
